Ziggy81's avatar
Ziggy81
Help me make an informed decision
Curious on what some of you think about if I can get away without using a hitch extension for towing my open deck car trailer behind a lance 825 I'm considering buying. The wife and I are trying to decide between a new L650 or L825. We really like the 650 because it doesn't come past the back of the truck, the weight, and the size of the windows. What turns us off about it is, it's not 4 seasons capable and the toilet is a little cramped. The 825 hits all our marks too and provides more floor space for the dogs, more countertop space, and plenty of bathroom. Not thrilled of the weight and the overhang of the 825. Below are the specs of my truck and trailer. I really want to avoid a hitch extension if I can manage to. My trailer rides low and has a long tongue
2016 F250 6.7 short bed
GVWR 10,000 lbs
Tire rating 3,750 lbs
Bed Length 6'10"
Airlift 5000 airbags installed in rear
Rear HD sway bar pending install
Trailer
Loaded 6500 lbs
Tongue weight 650 lbs
Deck 15'
Tongue length 74"
Top of tongue to truck bed distance 20"
Hitch Ball Drop 8" from truck receiver
Lance 825
Wet with gear weight 2400 lbs
Floor length 8'6"
Estimated overhang from truck bed 20"
Lance 650
Wet with gear weight 2147 lbs
Floor Length 6'10"
Estimated overhang from truck bed 0"
  • Ziggy81 wrote:
    Flat towing isn't an option since my jeep is wheeled hard and high potential for damage.
    The bigger camper 825 is for a short bed truck and the cog will be over the rear axle. The tongue weight of the trailer max is 650lbs but usually less because of how the jeep is loaded on to the trailer. As far as weight goes I'm not far off with ether camper and I agree, 250lbs doesn't make a huge difference.
    No offense but from other areas I read about this it seems like it's a knee jerk response that most people have saying I need a 24" extension to tow behind a TC. Looking at the measurements of my trailer compare to the overhang of the campers there's plenty of tongue even with a tight turn. Plus the 825 camper doesn't come down past the bumper to cover the hitch. Obviously not a worry with the shorter 650.
    Over the years we tend to forget the things we learn in school, but this is primary school math.
    Your original hitch + ball mount will put ball about 5 feet behind rear axle. Knowing the distance between the axles you can calculate how much 650lb on the ball will put on the rear axle.
    Now do the calculation adding 2 ft extension.
    Sounds like you think without extension your trailer will swing under the camper without interference. That might happen, but next time you put Jeep a foot farther on the trailer and you will have very bad day later.
    Or simple doing a turn while crossing a ditch can bring a disaster.
  • Would you have concerns about not having the all weather package in a smaller TC cooldavidt?
  • Flat towing isn't an option since my jeep is wheeled hard and high potential for damage.
  • I don't think the 250lb campers weight difference will be a big deal, but not only bigger camper will have COG to the rear, but you will need about 2 feet hitch extension what really affects towing capabilities.
    In final point that can make load on your rear axle bigger in the range of 1000 lb (if not more -when you load the trailer more up front)
    That also calls for SuperHitch.
    Would you flat-tow the toad, you would not have tongue weight what makes everything much easier.
  • On a 250/2500 and towing something, sorry, personally I would go as light as possible. What is the hitch weight of your trailer loaded as you would be pulling it? That has to be subtracted from your CCC b3fore you even consider adding a camper. BTW everything you have done to the truck does not add one pound to the MFGs listed GVWR number. And no, no one will stop you of force you to pull into a highway weight station, except in BC.
