Keithk3628
Sep 19, 2018Explorer
JTrac wrote:
I had a Titan replacement tank on my last 2 trucks. They work very well and by far are the most convenient. What I hated was I don't think I got anything for them when I traded trucks, in fact, I'm sure I didn't. So, money lost. When I got the new Ford last year someone on this forum, or maybe another one, not sure, suggested the Enduraplas 25 gallon transfer tank. It is easily removeable, as long as it is empty, which means if and when I get another truck it goes with me. I've used it several times this summer and it worked like a champ. The fill nozzle has an auto shut off which I tested and can confirm it works. It will empty the 25 gallons in less than 4 minutes.
Just another suggestion.
Appreciate your thoughts, and I am thinking of the aux for the same reason of new truck later, my problem is I have to keep the size really small cause I only have 8 inch's under the Reflex roll up cover box in the front, and the drain tubes coming from it only gives me 48 inch's width and 20 inch's of room before the slider hitch.
So I think I am tied to the RDS 20 gallon If I do it myself or the local truck shop will custom order one which adds about 8 more gallons for a total of 28. But of course the price for them to order and install doubles so that is a consideration.
Really appreciate everyones thoughts, really helps with the solution.
Keith
44,056 PostsLatest Activity: May 04, 2014
