Old-Biscuit wrote:
YEAH..older rigs used valves.
Then 'efficiency', 'productivity', 'cost savings' etc. and caps/plugs became the norm.
Those low point drains just need to be tightened and IF still leaking you can always replace with a couple of valves from hardware store.
Home Depot carries 'Sharkbite' which are really good quality and just snap on (Lowes carries similar but called Gatorbites)
what do you mean by just snap on? they are both just tubing coming out of the bottom...do the sharkbite just push onto the bottom of the tubing with a valve to open and close or something?
