rcp123's avatar
rcp123
Help with payload numbers
I recently got a new 2016 GMC Denial 3500 SRW Diesel. According to the brochure it has a payload of 4080lbs.
We are looking to get a Sandpiper 372lok which has a pin weight of 2474 and GVWR of 15,500.
We are a family of 4 and have been camping for many years. The 5er has a CCC of 2538#, but I really never see using going near that number. We have never came near it yet, and as our kids grow, their toys are get in much lighter (now iPads vs lots kids toys), so I don't see things getting any heavier.
But I want to be realistic.
Before we get our hopes to high, is my new truck capable of safely hauling this 5er.
Thanks for all your input,
Cheers,
Ryan
  • You have a 2016 3500 SRW with a payload of 4080# (is that what door sticker lists---Yellow sticker with 'Tire and Loading Information'
    It will list YOUR trucks payload (Cargo Carrying Capacity)
    15,500 GVWR 5th wheel.....
    Using a 22% pin weight-----3410#
    Your truck is quite capable of 'carrying' that pin weight
    Check trucks RAWR and Rear Tire Max Load Ratings
    Weighing truck fully loaded and camp ready is always best so you have real world numbers to work with
    No need to look for a 13,000# 5th wheel
    I tow 14K with my old 2007 3500 and am not over RAWR/Rear Tire Load witha 3000# wet pin weight
    And my 2007 has lower ratings then your 2016
  • The pin weight number you listed is DRY not loaded ready to travel. Double that number and you will be far closer to an actual pin weight. Load the family up with everything you can think of and drive across a set of scales. I would be suprised if you dont weigh around 8000 pounds. Meaning your real life payload including a hitch will be around 3000 pounds. But you also have to understand a fivers pin weight, what ever it turns out to be is placed directly over the rear axle. Which is based on your rear tires load rating. Glad your asking first, but I would suggest you start looking at fiver with GVWR around 13,000 pounds.
