Sjm9911 wrote:
JRscooby wrote:
Sjm9911 wrote:
Ok, so i have the ez lube axels or whatever they are called now. I will use them after i finish my break job. I really dont see how a normal hand pumped grease gun will push out the back seal. Hell, i have a hard enough time trying to pry out the rear seal with a hammer to repack them. The new seal is always tight goung in also. I can see if you re use an old seal, or dont put the seal in correctly that you might blow out the rear seal. But under normal operation. I cant see it happening. Now with that said, i would repack by hand every 5 years or so to check the bearings and races and such. But i plan on using the ez lubes for a few years for annual greasing after its set up.
Do you understand that somebody that does not know what they are doing with a hand pump grease gun can tighten the tracks on a D-6 Cat dozer so tight it will not hardly pull up on a trailer?
Gdetrailer wrote:
Which is the "conventional wisdom" that my Dad taught me back when I got my first car and he showed and explained step by step on how to repack the bearings.. Big rule was to not pack the hub center full of grease. Just pack grease around all of the bearing surfaces is sufficient.. Has worked well for me for several million miles of driving across multiple cars and trucks.
But I get it, not everyone likes to get hands dirty and grabbing a grease gun is very convenient..
Thank you
I know nothing of what you speak. Is the cat tracks the same set up as an ez lube axel? If it is i am surprised.
While my post had nothing to do with "cat tracks", I can see where that is possible to do given the correct parts are put under enough pressure from a grease gun..
Many folks in the "hit and miss" engine collecting community often resort to using the grease gun method for pushing out badly stuck/frozen/rusted pistons..
HERE is one mention of that..
Also have seen folks using same grease gun method to remove stuck brake caliper pistons for rebuilding the calipers..
HEREUsing a grease gun to grease wheel bearings are a quick fix for those that do not want to get their hands dirty, but with quick fixes, it comes at some risk.
Failure to follow the directions from the manufacturer will most likely result in grease bypassing the seal.
To avoid that you must rotate the wheel while greasing, that means you will need to put a jack under each axle and get it off the ground.
Grease on a nice warm to hot day, cold grease does not "flow" well and will be stiff.. That will cause pressure to build up higher than when warm.
Then because grease guns can develop a lot of pressure, you must pull the handle slowly. Hard and fast handle movements are where you develop the high pressure.
If this is the first time greasing, it may take a lot of grease, the factory does not load them up with grease and it takes a lot of grease to load the center hub chamber.
When you see grease pushing out the front bearing you can stop, no need to keep pushing.
Be patient, don't be in a hurry.
Myself, I have two trailers, one without EZ lube and one with..
I personally do not care for the ez lube axles, my inspection mechanic loaded them one inspection, now when the mechanic (or myself) pulls a drum we are greeted with a excess of greasy gooey mess to clean up. That grease pulls out in a big long greasy ribbon and leaves globs of grease on the axle stub..
I would rather pull and inspect my brakes periodically than worry so much about how much grease the bearings have.. Once you grease them the grease does not evaporate or disappear..
