BurbMan
May 04, 2022Explorer III
The problem is that the wood is rotted so the jack has nothing to attach to....the "repair kit" is to peel back the siding and remove/replace the rotted wood. Chances are very high this is not the only place you have rot., Good news is that aluminum siding is easier to repair/replace than filon. The bad news is that jack itself seems to be damaged now and not sure what that will take to rebuild.
What you'll find is that camper has been leaking at various places for years and this was the first place that rotted out bad enough to be a problem. If you want to rebuild, check the link in my sig for what you are likely in for. i wouldn't discourage you from repairing this be be aware of what you might be getting into.
If you look at the link in my sig to the Lance rebuild, this is excatly how it started out....the RF jack by the propane compartment gave out.
44,071 PostsLatest Activity: Aug 30, 2026
