calamus wrote:
Aluminum Siding wrote:
2x8s and a chop saw.
X2 I carry a 4' level put it on the floor and measure then boards under the wheels as needed then front to back I always tip just a little bit to the drivers side and to the back so the ac drains away from the door side of the camper.
Soooo awesome. I do the exact same. Use a little blue 4 inch level i put on the floor just inside the entry door. I error a tiny tiny bit high on the side of the door. You can get an extra 5+ gallons in your tanks and when you dump it flows out faster leaving less in the tank.
