PackerBacker wrote:
Boards under the tires to get it to where I want it. I don't use a level, I use the sliding door to the bathroom from the bedroom to get the left/right done and then I use the water flow to the shower drain to get the front/rear where it should be.
Seems like whole lot of trouble and time as opposed to using properly installed stick on levels. For one thing you have to go inside to check the sliding door and the water flow. :h
But if it works for you then that is all that counts. I just can't believe how this thread has taken off for something so trivial ... :)
