wmoses wrote:
PackerBacker wrote:
Boards under the tires to get it to where I want it. I don't use a level, I use the sliding door to the bathroom from the bedroom to get the left/right done and then I use the water flow to the shower drain to get the front/rear where it should be.
Seems like whole lot of trouble and time as opposed to using properly installed stick on levels. For one thing you have to go inside to check the sliding door and the water flow. :h
But if it works for you then that is all that counts. I just can't believe how this thread has taken off for something so trivial ... :)
It was a habit from doing the same with the levellers on our Class A. I found that levelling with my 3' level didn't necessarily get to where the bedroom/bathroom door would stay closed properly. I guess the door was not 'level' inside the trailer. The other way, I just want to make sure that the shower water flows towards the drain and doesn't pool. Again using a level for front to back is likely easier however, one thing I should of mentioned is that when we set up, it's for 3-4 months at a time.
... Eric
