GordonThree
Feb 26, 2014Explorer
westend wrote:
If you install batteries just behind the axles, you'll decrease tongue weight. If it's necessary to mount them inside the cabin of the trailer to accomplish this, you'll need a battery box that is vented to the exterior. I have two 6V's in a vented battery box inside my rig. I did it to better balance side-to-side weight and keep some weight off the tongue. It is a fair bit of work to make it happen.
I second this approach. If you buy your GC2's from Sams Club, you can get Duracell (East Penn DEKA) AGM golf-car batteries, which do not off-gas nearly as much as flooded batteries... they are rated for indoor use.
I put several AGM in a storage cubby that's part of my dinette. They are rear of the axle maybe 12 inches and did not affect the tongue weight of the trailer in appreciable amount.
When you add new batteries to the rear, any chance you can remove those batteries from the tongue, this will help with your weight? Unless you're spending a lot of money on HEAVY cabling, the two banks will not be working in parallel to drive large loads.
