tkoden
Feb 26, 2014Explorer
When you add new batteries to the rear, any chance you can remove those batteries from the tongue, this will help with your weight? Unless you're spending a lot of money on HEAVY cabling, the two banks will not be working in parallel to drive large loads.
Yes, the plan is to remove the batteries from the tongue. The net would be 300 lbs roughly 150 off the tongue and 150 added weight on the rear.
