adamis
Jan 10, 2021Nomad II
How much weight could be eliminated?
A bit of a hypothetical question here but I got to wondering how many items on a camper could be eliminated while still providing a camping experience with minimal compromise. To that end, I thought it would be an interesting exercise to list the items that could be eliminated or replaced with something else and to list what those weight savings might be. Note that this is an exercise only so cost isn't a factor and some of these suggestions are probably not suitable for all climates.
The items I can think of (not exhaustive, feel free to add to it) that could be eliminated / replaced and the estimated weight (if it say's unknown and you think you have a good estimate feel free to add it in) are:
1. Jack stands
Weight: Unknown
Alternate: None Needed
Alternate Weight: None
Weight Savings: Unknown
Alternate Notes: Can't remove from bed or reposition if needed
2. Lead Acid Batteries
Weight: ~160lbs (6v AGM Lifelines x2)
Alternate: LiFePo4 100AH
Alternate Weight: ~30lbs
Weight Savings: ~150lbs
Alternate Notes: Requires upgrade in other electrical items
3. Genset
Weight: Unknown
Alternate: Possibly add 1 additional 100AH LifePo4
Alternate Weight: 30lbs (1 additional battery)
Alternate Notes: Not ideal in warmer climate areas
4. Furnace / Water Heater
Weight: 30lb furnace, 24lb water heater
Alternate: Combi D 6 Diesel Heater / Water Heater combination unit
Alternate Weight: ~31lbs
Weight Savings: ~23lbs
Alternate Notes:
5. AC Removal
Weight: ~80lbs
Alternate: Fantastic Fan
Alternate Weight: ~10lbs
Weight Savings: ~70lbs
Alternate Notes: Might not be suitable for all climates
6. Oven / Stove Removal
Weight: Unknown
Alternate: Countertop gas or electric burner
Alternate Weight: Unknown
Alternate Notes:
7. Microwave Removal
Weight: 27lbs
Alternate:
Alternate Weight:
Weight Savings: 27lbs
Alternate Notes: Some, not all users don't need a replacement for a microwave
8. Gas Fridge to Compressor Fridge
Weight: Unknown
Alternate: DC Compressor Fridge
Weight Savings: (might be no weight savings but allows for removal of propane bottles)
Alternate Notes: May not be actual weight savings
9. Eliminate Propane Bottles
Weight: 37lbs each (Typical Camper has qty 2)
Alternate: None
Alternate Weight:
Weight Savings: 74lbs
Alternate Notes: Requires switching to DC Fridge, Diesel Heater / Water Heater and alternate stove top.
That is about what I can think of right now. If you have some information (like Jack Stand weight) please post the information. If you have alternate suggestions or additional items that could be removed / swapped, please add it to the list using the same format.
1. Jack stands
Weight: Unknown
3. Genset
Weight: Unknown
Alternate Notes:
5. AC Removal
Weight: ~80lbs
Weight: Unknown
Alternate Notes:
Weight: 27lbs
Alternate:
Alternate Weight:
Weight: Unknown
Alternate: None
Alternate Weight:
