Harleybullet's avatar
Harleybullet
How much weight to tow with TC
I have a 1999 Ram dually Cummins diesel(5.9), Quad Cab with a 3.55 rear end...My question is if anyone with this set up, how much weight do pull with a boat or trailer?
  • My F350 is rated for 22,000lb pull.
    But it is the weight distribution that will be your limit with long camper
    The members who pull 10k lb trailers had to go to heavy trucks just to get suspension who could carry the tongue weight on stinger.
  • Pulling wise, you can pull a bunch, but the limiting factor is the rear axle.
    First thing you will need to do is weight the truck loaded for a trip and see how much additional weight you can put on the rear axle. Without knowing that, would only be wildly guessing at how much you can tow with the camper.
