KFCCaravan's avatar
KFCCaravan
How Roadworthy is my rig?
Hello everybody
Long time lurker, first time poster here.
My name is Brett, and my wife and two daughters (aged 4 and 1) are super excited to announce that we have just purchased our first travel trailer. We have signed on the dotted line and the unit is awaiting pickup in a couple of weeks.
The trailer is a 2014 Coachmen Clipper 17BH. We chose this unit primarily for it's layout coupled with light weight. Of course the budget was quite limited too. At 22 feet, it is also at the limit of what I can fit in my backyard which is important.
Specs of the Clipper 17BH:
Hitch Weight: 406lbs
Exterior Length: 21'8"
Width:88"
Exterior Height: 9'8"
Base weight:2818lbs
GVWR: 3626lbs
Single Axle, electric brakes
I have never towed before and wanted to remain on the safe side of my vehicles towing limitations. The tow vehicle will be a 2014 Grand Cherokee V8.
Specs of the Grand Cherokee:
Curb Weight: 5324 lbs
Wheel Base: 114.8"
5.7L V8, 360hp, 390ft/lb
4wd, 8 speed auto
The tow limit is 7200 lbs, tongue limit is 720lbs
Payload: 1090lbs (a little on the low side but manageable)
I have installed a Tekonsha P3 brake controller and the dealer is equiping my trailer with a weight distributing hitch. I believe that I am ready to pick the trailer up and I'm just waiting for the weather t stabilize a little more.
I must admit I got a little excited and really jumped head first into all of this and I lack any experience. I did not test drive my trailer with my tow rig and perhaps have made some hasty/unwise decisions.
So I guess what I'm looking for here besides sharing my excitement with all of you is opinions on how my setup will function on the open road. I will be doing a lot of towing in the mountains through relatively high elevations at times. I know that my tow vehicle has a shortish wheel base and I certainly do not want to be swaying back and forth in the wake of semis with my family on board. I want this to be safe first and foremost.
What do y'all think? Please keep in mind that we have already purchased so changing trailer models is not really feasible at this time.
Thanks
  • beemerphile1 wrote:
    Welcome to the forum.
    I see one issue immediately. Many of the approximately 3,500 range GVWR trailers have very tittle cargo capacity. Yours is no exception.
    The as built weight will likely be more than the 2818 base weight. You will have to be very careful at how much gear you pack. Water alone weighs 8.3# per gallon. Fill that 33 gallon fresh water tank and you just added 273# which is 1/3 of your cargo capacity.
    Make sure you get a good weight distribution hitch. Many of us like the Equal-i-zer brand.
    Cute trailer;
  • Welcome to the forum.
