Gaetan's avatar
Gaetan
How to join a photo to a topic
Can you explain how I can join a photo to my topic
Gaetan
  • Here is the new link:
    1492 is a genius, in my opinion
    1492 is a moderator, and he developed this app for us. Bless him! This is so easy. Just save that link in your bookmarks, drag a photo into the box, copy the code that pops up, and paste the code into your thread. Boom. Done.
  • The link may be broken to upload pics:
    DROPBOX no longer supports HTML based files to render in browsers. A new Photo Upload Webapp URL link will be provided once available.
  • What OLDMAN said!
    This was provided by an RV.net member. Of all the ways to do picture posting it is the easiest.
    No need to resize, no need to use the image box in the post message menu. Just copy and paste the URL that the program presents after loading your picture from your computer!
    I have corrected the link below to be the right one....
    http://photoposting.is-great.net/?i=1
    Bookmark it.
    Play with it.
    Jim
  • woodhog wrote:
    Joe417 wrote:
    I believe it was one of the rv.net moderators that created the link below to help with posting pictures. It works great.
    At your home screen, right click, select new, then shortcut. Copy the link below as the location, select next and give it a name like RVnetPhoto, then select finish. This short cut will take you to the picture hosting site quickly any time you need to post a picture.
    I keep it on my home screen next to my rv.net short cut.
    To post a picture, double click your newly created shortcut "RVnetPhoto". Drag the photo you want to post to the host window and drop. It will return a link. Just copy the link and past it into the rv.net message window.
    You won't see the photo until after you post the message.
    Will the photo automatically be sized properly when you use this procedure?
    You'll get the hang of it after a few posts.
    http://dl.dropboxusercontent.com/u/201045551/Forums/PhotoUpload/RV.NET-Photo-Upload.html
    try it
  • I believe it was one of the rv.net moderators that created the link below to help with posting pictures. It works great.
  • The first Sticky post in this forum talks about that. Also Forum Tech support.
