KillerIsMe's avatar
KillerIsMe
I hope I'm barking up the right tree
I have never owned a TT before, although in a previous life I pulled a two-horse trailer all over the Northeast. I was young and carefree back then, never gave towing much thought - just hitch and go. I'm not so young anymore and I care now so I've come here to ask your advice.
My TV is a 2014 Nissan Frontier V6 4WD with the factory tow package, and I'm not upgrading. I've had the truck since new, owe about $2500 on it, and it has just over 30,000 miles. It's a good every-day truck and I'm just not prepared at my age to turn a small amount of debt and a reliable known into a big amount of debt and an unknown. So I did the math on the truck's payload, added in myself, my wife, our daughter, the dog, and added in 70 extra "miscellaneous" pounds and I'm left with a maximum of 570 pounds on the hitch. Realistically I want to stay away from maxxing out so I'm trying to stay with a total hitch weight of 470 pounds or so.
We are trailer shopping and have funneled down our choices into our favorite, and that's a Venture Sonic Lite 168VRB. We went to look at one today and the real-world factory sticker shows the Sonic at a 250 pound hitch weight (dry of course), and a trailer weight of 3200 and GVWR of 4000. That unit has the options we want with the exceptions of TV and power tongue jack. The Nissan is rated to pull 6100 pounds, which I had no intention of doing, and as I said I have up to 570 pounds left of payload for the hitch. Can you folks help me out on this: am I OK with this combination? I will not be camping much more than 12 to 15 trips per year, and as we live in Northeast Pennsylvania we will stay mostly local.
Am I missing anything?
  • You are going to be close to your max cargo rating, if not a tad over. You are going to have the trailer pretty well maxed out. That dry weight does not include batteries and propane, or your belongings and food. If you have the trailer at 4000, your tongue weight needs to be between 10 & 15 percent for good towing, or 400-600 lb.
    Make sure that your tow package includes a transmission cooler. You will need a 7 pin pigtail, a brake controller, and a good hitch with weight distribution and sway control. Andersens are good and weigh less than 60 lb.
    I would not want to do any steep grades or long trips with this setup, but you are probably OK for shorter trips.
    Another option is a popup, or a folding trailer such as an A-liner.
  • Looks like you've done your homework. Try to get actual trailer weights off the yellow sticker they come from the factory with. That will give you a better number than the brochure weights. You can estimate how much weight you will put in it to get an approximate tongue weight or use the trailer GVWR to find the max number. The average is around 12 percent of trailer weight carried on the tongue. If the trailer you're looking at is 4k GVWR you should be fine.
