Might not mean anything but Carlisle warrants for 2 years, Maxxis for 5 years.
Carlisle Warranty;
Highway/Non-Highway Tire Warranty
Limited Warranty
The Carlstar Group LLC warrants, subject to the terms, conditions and limitations stated herein, The Carlstar Group’s tires and wheels to be free from defects in materials and workmanship. The Carlstar Group’s liability for tires and wheels shall be limited to replacement of any defective tire or wheel plus any applicable taxes.
1. THE CARLSTAR GROUP PRODUCTS WARRANTY applies only to the Original Purchaser of The Carlstar Grouptires and/or wheels for TWO YEARS from the date of purchase.
(a) The Warranty for the coating of the wheel is for a period of ninety (90) days from the date of purchase.
2. The Warranty is void if the tire or wheel fails due to damage from improper inflation pressures, exceeding the maximum speed limit, or overloading the tire beyond the maximum load capacity stated on the sidewall.
3. The Warranty does not cover incidental or consequential damages, including, but not limited to, lost time, inconvenience, loss of vehicle use, cost of towing or transportation, related property damage or consequential damages of any type or nature.
4. The Warranty does not cover mounting and balancing charges.
5. The Warranty is void if a covered tire is worn past last 3/32 of tread depth at any point on the tread contact surface.......
Maxxis Warranty;
Subject to the limitations contained in this Limited Warranty, your new Maxxis tires are warranted under this Limited Warranty against failures due to defective materials and workmanship for a period of five years from the date of manufacture.
A. Eligibility: A tire is eligible for warranty coverage under this Limited Warranty only if the tire is presented by the original owner and consumer within five years from the tire’s manufacture date and the tire has a minimum of 2/32” of tread depth remaining, and all procedures in this Limited Warranty are followed.
B. Free Replacement: Subject to the limitations contained in this Limited Warranty, if a Maxxis tire fails due to defective materials or workmanship during the first 25% of treadwear on the Radial ST or twelve months from the date of original purchase, whichever comes first, the tire will be replaced with a new comparable Maxxis tire without charge. Notwithstanding the foregoing, out-of-round tires must be presented for free replacement within the first 2/32” of tread depth.
C. Treadwear Prorated Discount: A defective tire that does not qualify for free replacement under (B) above, but that is otherwise eligible for warranty coverage under this Limited Warranty, will entitle you to a discount on the purchase of a comparable new Maxxis tire. The amount of the discount will be calculated based upon the percentage of tread that remains on the defective tire. For example, if 60% of the original tread remains on the defective tire, you will be entitled to a 60% discount off of the retail price of a comparable new Maxxis tire. You are responsible for all labor costs for mounting and balancing and for all applicable taxes.....
