2012Coleman wrote:
Lowsuv wrote:
if you actually want to get the highest load rated tire the answer is clear :
Goodyear Cargo G26
size : 225/70 R 15
Rated at 2470 # load on the LT rating scale
Not the 15 % wimpier ST rating scale .
Speed rating is 106 mph .
This tire weighs 33 # .
Load range D means you only inflate to 65 psi to get your max weight rating .
It fits on most 15 inch rv steel wheels without issues .
The typical Maxxis (and other ) ST 225/75R15 weighs about 29 # .
The Cargo G26 is made for European passenger vans such as the Mercedes Sprinter Vans .
readily available on tire rack and every goodyear dealer .
go here for complete specs :
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Cargo+G26&sidewall=Blackwall&partnum=27R5G26&tab=Sizes
I'm in the market for tires - this one looks like a good candidate to replace mine which are ST 205/75 R15.
Question - what is the difference in size between mine and this one?
And, are these LT tires?
I bought the 195/75r15 to replace my 205/75r15. The 225s might be to large. These tires are soo much better than the original Chinese junk tires. Had them for a year now and over 4000 miles. Totally happy with them!
