- towproExplorerI use one of these, with outdoor sensor right under the loovers in the propane door.
Click here
I hold it on wall with that new 3m tape you see on TV made for hanging things on the wall. - AidenJExplorerWe have the Acu-Rite wireless. the outside part is velcroed to the under side of the wing and has riden there many miles. seems to be very accurate. I think we bought it at walmart.
- BumpyroadExplorerhave one from walmart under $10 IIRC
bumpy - kenzmadExplorerHarbor freight has one. I use one to tell the inside temp of the camper and the other is mounted in the fridge. Way more accurate than the fridge thermometers out there
- Golden_HVACExplorerWal Mart has several. I prefer the wired outdoor sensor, as you do not need a second battery that is transmitting, and the indoor unit does not need to run a radio receiver all the time too. .
Home Depot, Lowes, Ace, all have wired and wireless indoor outdoor thermometers. Some have humidity too, also very handy to know. . .
I can slip my outdoor sensor through the space where the windows slide together, and it stays on all the time, even while driving. I used to have a wireless one, and would hang it from the outdoor bracket that I also could hang my gas lantern, but many times would forget it there when I drove off (it hung on good in 65 MPH winds on the freeway). .
Currently I have a wired outdoor sensor in my bedroom. There is a space below the nightstand for air to return to the living area from the basement (to allow heat in there) and down to the basement door, outside, and secured to the framework there. However it will read 120+ when driving, I am guessing the engine radiator heat? So it is most accurate after being parked for 30 minutes.
Good luck,
Fred. - JoeTampaExplorerCW has several; I just bought this one to replace a B/W, non-backlit model. The outdoor module is zip-tied to the frame underneath my TT.
http://www.campingworld.com/shopping/item/wireless-color-station/74812
44,029 PostsLatest Activity: Mar 16, 2025
