JohnBee
Dec 29, 2015Explorer
I had the exact same issue "the bulge" on my '02 10-2000. I attempted drilling holes through the shell and injecting Sikaflex. It was a slight improvement, but it annoyed the hell out of me and I ended up ripping the interior out behind the affected areas. Right behind the bulge there is in fact no foam at all but rather a pathetic little piece of plywood glued to the shell in this highly stressed area. I glued (Sikaflex) a large 1" plywood reinforcement about 5 times larger than the original. By cutting the luan strategically in the interior to gain access, you couldn't tell it was ever repaired. In the end it was a lot of work but fairly inexpensive.........just some plywood and adhesive. When I had it torn apart I could see how futile injecting the adhesive from the outside was. The foam in the lower wall had come completely unglued.........the foam doesn't break apart, the glue just gives up.
44,070 PostsLatest Activity: Aug 05, 2026
