rbpru
Oct 12, 2016Explorer II
Jeep can and do pull all sorts of loads, that does not mean they do it well or comfortably.
The easiest thing to do is to rent a similar size and weight TT for a week or so before you spend the big bucks. You will learn a lot.
Cargo capacity is also an issue. Even if you like the way it tows, it is not good if you are over your axle capacity across the scales.
Good luck
Good luck
