- jerem0621Explorer IIsounds perfectly normal to me.
- grovegang52Explorer
Bull Rider wrote:
Just to check your procedure, you're attaching the sway device at both ends, and then tightening the hand crank fairly tight? There will be a little wiggle until you compress or tension the device. It should then be fairly snug. If it's not under compression or tension is will feel a little loose.
Yes, that is correct. I guess I just figured it would not move at all, with the exception of sliding in and out. Thanks for the advice. - usmc616ExplorerWhen we used a friction sway control device it always had some movement when hooked up properly.
- Bull_RiderExplorerJust to check your procedure, you're attaching the sway device at both ends, and then tightening the hand crank fairly tight? There will be a little wiggle until you compress or tension the device. It should then be fairly snug. If it's not under compression or tension is will feel a little loose.
- JJBIRISHExplorerNormal… it has no fore or aft pressure on it just sitting there…
- K_CharlesExplorerYes there is some wiggle on the two balls.
44,066 PostsLatest Activity: Apr 10, 2026
