kohldad
Nov 20, 2017Explorer III
Need to get a trip or 2 under my belt and see about what suspension upgrades are gonna be needed.
With just the camper, I think all you would need is a rear sway bar. I would go ahead and add that, because you will definitely need it.
For the trailer, check to see if you can get by with an 18" extension. If so, just run a weight distribution hitch and you should be good. The WDH would also help alleviate the tongue weight effect on the rear axle which will help because that is where you wil be pushing the limits. But you may still need air bags to boot.
For the eyebolt, it will be one like this: lifting eyebolt.. Don't use the ones that can be opened for obvious reasons. Double check the size, but if my fuzzy memory is working, it is 3/8".
44,066 PostsLatest Activity: Jul 25, 2018
