Seems there is a lot of controversy over where to place a jack on a 2-axle travel trailer to change a single tire or service wheel bearings.
All rv forums are like that mainly because many rv owners are pulling their first trailer or haven't been introduced to a easier or safer way to change a flat tire.
Then you have some that may make a living by jacking trailers/vehicle for some type of R&R or maintenance daily.
Then other who may have made a living pulling all type of trailers with years of jacking a stupid trailer that gave the driver some thing to do and caught a flat tire.
I have a old 2 speed 4500 lb scissor jack with a 56" handle that I started with in the late '60s. It has a 4" wide X 6" long saddle that works great under the axle tube next to the U bolts. It cranks down to maybe 4" tall and my go to all purpose jack around the place.
Later in the early '70s the company I sub'd with came out with 12 ton stubby hyd jacks. The jack came with a round axle adapter that cradles 1750 lb up to 12000 lb axle tubes.
Slide either jack under the end of the axle next to the U bolt and raise one end of the axle high enough to get the spare back on the wheel. Both have a 10" X 10" wide base for soft side of the road conditions.
One problem lifting the whole side of the trailer with the suspension hanging or let one axle hang is side links can flip causing several problems. BTDT and not fun on the side of the road getting the link to flip back in the right position.
Everyone has their way of raising the trailer to change a flat or R&R. There is no correct way as trailers (rv and non RV) vary in weight from 2000 lbs up to 25000 lbs. Make a different in what works.
