bowler1
Apr 30, 2018Explorer
Using Leveling Jacks to Change a Tire?
Hi,
Can you safely use the leveling jacks to raise the tires on one side of the trailer to change a tire (or in my case so that I can adjust the brakes)? And if so, what is the best way to do this?
I ask because I have my new 5th wheel set up in my driveway and my automatic leveling system set the jacks such that the passenger side wheels on the trailer are a couple of inches off the ground. So I assume I can use the leveling jacks to raise the other side to adjust the brakes on the drivers side.
If this is the case, what would be the best way to do this without putting excess stress on any components?
I assume I would (after putting all the slide outs in) raise the rear jacks such that only the front jacks are down. Then lower the rear jack on the side I want to raise. Then simultaneously lower the front and rear jack on that side until the tires are off the ground a bit.
Or would be be better to start with all four jacks down and then simultaneously lower the front and rear jacks on the side I want to raise.
Or...is it better to start with all 4 jacks down and then continue to lower only one of the jacks on the side you want to raise?
I just don't want to put excess stress on any of the jacks or the frame.
thanks for your help
Matt
Matt
