ssthrd's avatar
ssthrd
Jacking points on a travel trailer
I have read and heard that you should never jack a travel trailer using the frame, the axle, or any suspension part. Kinda eliminates all options as far as I can see, other than rolling one tire up a ramp to raise the other one off the ground.
I have a Wilderness 2750RL. Are the frames on these things too flimsy to be used as jacking points? I would hate to jack the thing up and have the frame fold up on me.
Any real world opinions based on experience?
  • ssthrd wrote:
    For now, I am only doing maintenance--repack bearings and have a look at/adjust brakes, so I will be hooked up but no WDH.
    Nah dont even hook up the truck if thats what youre doing. Jack up one side at a time and do what you need to do.
  • Mike134 wrote:
    naturist wrote:
    I've had a couple flats on a tandem axle trailer. Fastest/easiest/safest way to do it is put leveling blocks down, run the good tire up on the blocks high enough to raise the blown tire off the ground.
    Don't forget to remove the WDH bars before driving up. They shift weight to both trailer axles and front truck axle
    Never thought about that. Sounds like good advice. Next flat on the road (Wait--what?) I will disconnect the bars.
  • “Now having said that I did bend a frame on a fully loaded 38'..”
    Interesting. Do as I say, not as I did?
    Jacking a trailer ?? Much depends on what I'm going to do.
    Experience ?? 1.2 million miles towing non rv trailers for a living has shown me a lot about what worked better for my jacking situations.
    If its a simple changing a fl;at tire out on the road I use a Truckers Special 12ton shorty hyd bottle under the axle tube (leaf spring axle) next to the U bolt. The jack came with a adapter that slips over the top of the jack and cradles the tube. I've used it on every size axle up to 11k lbs that Dexter made.
    A short trailers frame like you have will not fold. Someone has a big imagination. Now having said that I did bend a frame on a fully loaded 38' GN flatdeck by placing one jack under the frame. A big rig repair shot fixed my rookie mistake in short order.
  • Thanks for the ideas. Ramp sounds painless, so I'll give it a try.
  • I've had a couple flats on a tandem axle trailer. Fastest/easiest/safest way to do it is put leveling blocks down, run the good tire up on the blocks high enough to raise the blown tire off the ground.
  • I set the jack stand right next to the front and rear trailer tires. Then roll the jack right next to the stands.
  • I’ve never jacked up a trailer and only buy TTs with tandem axles. I loosen the lugs on the flat tire wheel, run the good tire up a home made wooden ramp and change the tire. Faster, safer.
  • I jack my 5er on the very end of the axle, using the plate that holds the springs to the axle. The idea is to not just use the bare axle itself.
