- GWolfeExplorerThanks for the reply ElBesoBlanco, I didn't realize there was a furnace in addition to the heat pump, no problem then.
- ElBesoBlancoExplorerGWolfe, the heat pump wont work with outside temps 30F or below. If I wanted heat then I need to use the furnace when temps drop below 30F. The thermostat works great in maintaining heat when furnace is in use. (The Cool Cat heat pump A/C is all operated on the easy to use thermostat)
The A/C works great, but I have yet to use it regularly as the Cool Cat fans are super efficient in cooling the interior if trying to escape the heat. I also run the Fantastic Fan in reverse to pull warm air out. My 2000W inverter generator can run this with no problem, if neccessary (not A/C). I have done 3 days with no power in 100 degree days using just the cool cat amd occasional battery charge with the generator. I now have portable solar panels that regenerate my battery power but still love the lightweight generator as back up.
The gear deck is awesome! I like being able to carry home the dirty stuff (bikes, motorcycles, equipment, etc without having to stow it inside or take up room in the truck bed (I haul my two large dogs in crates in the covered truck bed) - GWolfeExplorerI like it more options and competition is a good thing. As much as I like my little pup I am getting tired of the set up/tear down and the foul weather protection. Since it is usually just me in the pup something like an A frame could work. I would worry about the heat pump/AC for a couple of reasons, the first being the AC on the floor, I wonder if cool air would make it up into the upper areas. The second would be getting enough heat when the temps drop, last time we were out the low the last morning was 8 degrees, I don't know how well a heat pump would work at that temp, that and probably needing a generator or electric hook ups to run it.
I would love the front deck to haul my ATV on, when I haul it in the back of my pick up there is no room for anything else. - bondebondExplorerRoyB, I'm anxious to see what you actually shake out for your upgrade(s). Be sure and post pictures of the progress and even any plans or drawings you come up with.
I am living vicariously through others' as life right now has put a halt to my own upgrades and mods. I seriously think camping (one of our favorite things to do) is in jeopardy this year. Only time will tell. - RoyBExplorer IIII will be staying with older 2008 Starcraft 14RT R/T Series trailer. I have been complicating a "WAR WAGON" upgrade for my OFF-ROAD Trailer to include new batteries, solar panels on the roof with two removable to be used as portable panels on the ground, A different arrangement of the deck with a move towards better covered storage of supplies and emergency items...
We have never got into the just carrying an ATV - just supplies with our unit.
My ultimate goal to beef-up my front deck much like Australia did with this style of OFF-ROAD trailer...
Changing my front deck to something like shown here would really do what I am wanting to do with my OFF-ROAD trailer. My main box is a 12-foot box so the whole thing should really give me lots of room and a more safe and protected way to carry all of my emergency support supplies better.
My trailer not only supports OFF-ROAD camping but is my center for emergency radio communications operations in remote locations complete with easy up antenna support for long wire HF dipole/off- center dipole setups..
Been wanting to do this for a couple of years and with my present down spiral of the sir year old original batteries this is the time to start making my plans to come to life...
I just got excited to hear on here that the ALINER type trailer is getting some visibility and learning of a couple of different I should be looking at a few thing like the on-board air conditioner/heat pump and perhaps my hyrdonic hot water distribution heat source... I got just the spot to move my roof mounted air conditioner unit to the floor of my OFF-ROAD trailer with something like the DUO-THERM COOL CAT heat pump unit.
I was just surprised that STARCRAFT was moving away from the rugged beefed up frames their R/T OFF-ROAD series trailers originally had.
Like one post here said I already have the best plan for the beefed up OFF-ROAD trailer design with my Starcraft R/T series trailer. The Australia design for OFF-ROAD suspension has some merit as well...
Roy Ken - ElBesoBlancoExplorerRoyB, my Flagstaff A-Frame Toyhauler has 6" frame under the body as well as the deck. The deck has a weight capacity of 650 lbs. The two rails come off and are used as ramps for ATV or motorcycle.
If you like the Jayco & still interested in an A-Frame, maybe check out the Flagstaff or Rockwood. They come with the Cool Cat as a standard option and the Jayco/Starcraft seem like replicas in floorplan of the Forest River brands - RoyBExplorer IIII just got some info on the frame under the Starcraft COMET setup. Looks like the biggest frame rail is 2X4 tubing... My OFF-ROAD 14RT has 6-inch tubing under the main body of the trailer and the deck and A-frame for towing is a massive 8-inch tubing... Have been thru a couple of rock bed creeks with so far haha...
One of the places I go to regularly up near a place called FLAGPOLE KNOB behind Harrisonburg VA looks like this. I cross this area just fine with truck towing my RT14
I did learn something else from talking with JAYCO about their DUO-THERM COOL CAT Heat Pump floor mounted Air conditioner made by DOMETIC. I think they said this COOL CAT unit has been around since 2009.
this is mounted in a cabinet in the high side wall of their new COMET ALINER type trailer. Has both air conditioning and heat. It claims the heat will run down to 20-30 degrees outside which may be a downside thing. I think I read it only draws 9AMPs for the compressor and 2.5AMPS for the blower. My 2KW Honda Generator would love that haha...
You can see the A/C heat pump installed in this CHALET high walled trailer.
This would really free up more weight on my electric raise roof and maybe allow me to add more solar panels. My roof mounted A/C is just right at the edge of working with my 2KW Honda generator. I can shut down everything and get it started but just as soon as it cycles the first time it trips my Honda breaker haha... I have run a 8000BTU home window unit from my 2KW Honda generator just fine...
I might look into one of these heat pump units... - ElBesoBlancoExplorerOH I agree - he has a kick butt set up! If not for the two bubble windows at the dining area and the large one over the sofa/bed area, ours would definitely be slopey and small feeling. I forget other brand A-Frames dont all have the bubble windows on both sides - they make all the difference of small to spacious in a 12 ft box. If my spouse has to walk around inside, I will boot him outside to a hike or bike 'til he is ready to settle and relax inside haha. We also have more floor space because we chose a model with a pull out sofa bed - and keep it a sofa until we retire for the night. When I take ot out by myself, I leave it a sofa and sleep on the dining side. I use the trailer more than him since I travel to shows but he had input of absolutely NO consideration for a tear drop...it was too much of a rolling mattress for him. haha
- Mike_UpExplorer
ElBesoBlanco wrote:
LOL Mike Up - Have you spent any time in an A-Frame? I ask this in good spirit :-)
because I made the same comment as you did until I physically sat inside one and realized how amazingly deceiving the A-Frame is!
My spouse is over 6 foot tall and plenty of head room and space for him to stretch out and relax. Our A-Frame is perfect for one or two but would definitely fall into "claustrophobic category with 3-4 in it.
I hear that claustrophobic comment alot when I am at events in the trailer. I invite them in tp take a peek and they always leave as surprised as I was the first time I sat in one.
Yep, I did sit inside a few and the sloped ceiling and lack of walk room due to the beds being in the box really made it cramped. I also don't understand tear drops when a more spacious tent can be use. Perhaps for parking lot sleep overs?
Like I said, I had the same floorplan as his pop up and it offers everything, high ceiling height corner to corner, bathroom, 2 large beds, complete kitchen with water heater and room to sleep 6 comfortably.
Plus his camper is already made for off road. He has a great camper that few can add upon in capability, livability, and quality. - ElBesoBlancoExplorerLOL Mike Up - Have you spent any time in an A-Frame? I ask this in good spirit :-)
44,066 PostsLatest Activity: Mar 14, 2015
