It's actually BEFORE you purchase that issues like that should be considered. Back the trailer up on leveling boards that are high enough to act as a work around but you will likely ALSO find driveways into gas stations, restaurants etc. to be more of a problem with the low ground clearance. This is especially so if you have a longer trailer with a long overhang. Really not very suitable for anything except perfectly level ground as found in many RV parking lots. Most "campgrounds" are not so flat either.
