Ski_Pro_3's avatar
Ski_Pro_3
Just tossing it out there; I'M FAT!!
Finally weighed the truck with the camper, full water, propane, fuel, generator, dog, etc., all loaded up and ready to go. You name it, we packed it.
2006 Dodge Ram 2500 Laramie Package w/diesel, 6 speed manual tranny and 4x4 short bed truck and all the bells and whistles for suspension mods; overload springs, air bags, shocks, sway bars, rims Toyo 3750lb rated tires, etc.
2012 Lance 855S camper with solar panels, AC, 2 stage heater dual propane tanks 2 batteries, packed with enough food for a week for two people and a dog and full 30 gallons of fresh water.
Rear axle 7250 pounds
Front axle 4550 pounds
Total; 11800 pounds.
I have NO idea what my truck is rated at. I peeled off the door stickers when I bought the camper so I wouldn't let it worry me!
She drives like a dream; just went up to the mountains fishing for trout, then straight to the central valley for a few days of goose hunting. Total 500 miles of driving from sealevel to over 6,000 feet with lots of 70mph freeway speed limit. I never drove over 63mph. I stopped a couple times to check tire temperatures. By my hand, they were just barely warmer than the ambient air temps so I knew they are not getting hot flexing. Running full air pressure in rear tires, 65psi in front tires and 30psi in the air bags.
Anyways, I always find it interesting when other guys post up their stats so I thought now that I found a REAL scale, I'd do it too.
Cheers!
  • skipro3, did you weigh the truck and camper i.e. both axles on the scale at the same time?
  • You might try another scale. I've had some "certified" scales be way off on my truck.
    That's one way to deal with a 8,800# GVWR :S
    Well, Lance 'says' the camper weighs under 3,000 pounds. So if I removed my camper from the 11,800 pounds I measured, I'd be at max load EMPTY!!!!
    I guess I'll now have to weigh the truck empty and see what the difference is...
  • newman fulltimer wrote:
    So if you peeled the stickers off to not worry about it why did you weigh it then?
    What I said; " Anyways, I always find it interesting when other guys post up their stats so I thought now that I found a REAL scale, I'd do it too."
    To elaborate;
    Curiosity. I was wondering about my tire ratings mostly. Wanted to know what my mpg was getting me for the load I was hauling. Also wanted to see if the diesel engine was really all that powerful or I was lighter than I imagined. I'm impressed with that Cummins engine and what it will deliver hauling me up and over the mountains I frequent. All day long at any air temperatures, that engine seems to be barely working at that load! Great mileage too for that kind of weight I think.
  • Your GVWR is very close to 9000 lbs (my 3500 is rated 9900#). I'm sorry to say your way over but hopefully your upgraded tires will help.
  • So if you peeled the stickers off to not worry about it why did you weigh it then?
