FensterRV wrote:
Ok guys, been away from the computer but its great to hear about everyone's trip. My first one is 2 days away. Here are some questions maybe you can answer for me. Quite nervous- Some may seem stupid but remember I've never camped before!
1) After leveling the trailer and putting down the stabilizers, is the Bullet very bouncy? I've been reading about Steadyfast in case it is.
2) That stinks how quickly the gray tanks filled up. Teen age daughter and wife = many a full gray tank for me!
3) Can someone explain to me the proper method of turning on the water pump, and getting things ready to have hot water.
3) Does everyone run their AC 24/7? Its about 90 degrees here in NJ.
4) Give me a brief over view of the AUTO button and when that should be on.
5) Did anyone cook pancakes on the burner on the outside kitchen? Curious if it gets hot enough to accomplish this.
6) Thanks! If anyone has ample time, a review of a setup list when they get to the camp site sure would help. I'm more concerned with the internal stuff in the camper. Was Rainbows experience normal to trip the CB?
1. Any trailer that is as long as many of our Bullets are will have some bounce. Nature of the beast. If it bothers you then you can simply carry 2 manual jack stands with you when you are all done leveling and putting out the 4 stab jacks simply take your 2 manual jacks and put them some where near the middle of the trailer to help stabilize. Make sure the trailers frame is sitting on the jack. Walmart carries these jacks.
2. Hopefully a bathhouse will be near.
3. If there is no water at your camp site.....
A. Fill your fresh water tank.
B. When you get to the campground simply turn on the pump switch. It will be noisy for a few seconds while the pump fills the hot water heater and all of the lines.
C. If you need hot water fast turn on the gas switch on your water heater panel. After the water is hot turn off the gas switch and use electric to maintain it. Make sure both switches are off before you leave camp.
4. Auto button on the fridge? As far as I am concerned that button will always be on auto. It will make the fridge look for A/C electric power first and if none is present it will then go to propane. Maybe the only time I would not use auto would be if I knew that that the 30amp at my site was weak and had trouble starting the A/C then maybe then I would lessen the electrical load by using gas only.
5. I made oatmeal and it was plenty hot. NOTE: There as a little valve that you must open on the quick disconnect for the stove.
6.
