outdoordb
Mar 01, 2018Explorer
Keystone TT
I'm looking at purchasing a used 2016 or 2017 Passport, Bullet etc. I'm starting to hear bad things about anything made by Keystone and Thor. Let hear your thoughts. Thanks PS I hope this does not ...
myredracer wrote:
We have friends that own a Keystone TT that they bought new. After a couple of years the cabinetry and dinette was falling apart due to poor workmanship. I spent a day fixing it for them.
I've been to our local RV show a number of times and have seen Keystone units with obvious, in-your-face, bad cabinetry workmanship like cabinet doors that can't be closed due to improper installation of hinges for example. You'd think the dealer would go through a TT and fix things before thousands of prospective buyers parade through it.
The worst case about a Keystone TT was a guy we met in a CG. His roof leaked like a sieve from new. The dealer could not fix it and it got sent to the factory for repair, but the factory only made it worse. He ended up fixing it himself.
I've seen Keystone TTs on display at a dealer and just for fun have looked at GVWR and tire and axle capacities. Keystone will sometimes install tires and axles that are very close to their max. load ratings. No law against that unfortunately. Then an owner can end up with a blowout or bent axle and wonder why.
Personally, I'd never buy a Keystone but other owners claim to have had few issues. We were lucky with our KZ TT as it was one of the last to go out the factory door before Thor bought them out. If we were to buy again, the only one I'd consider would be an OutdoorsRV TT. Keystone uses bling as a lure but it's what you can't see that matters most. Choose wisely and don't get sucked in by the price because you can spend a lot more dealing with issues down the road.
A dealer can also be a big factor as many are inept at repairing things and can take forever to do warranty work.
