1 Reply
- JDsdogsNomad II
Most marker lights have a snap on cover/ lens. Under the lens are 2 screws. Remove screws and carefully pry the light base away from the coach body as base will be glued in place by some type of sealer. More often than not, you will find the wire and maybe connectors underneath. If no connectors, they often leave enough wire to allow you to splice in a new marker light.
