JIMNLIN
Aug 07, 2020Explorer III
The Truck I'm looking at is a 2020 Big Horn 3500 6.7 HO cummins Mega Cab 4x4 SRW. GVWR should be 12,300. Payload should be around 4K lbs.
A 4k payload will have to go on both axles as its a GVWR based payload.
The 3500 SRW Ram has a 7000 rawr. These trucks are heavy and rear axle may weigh 3400-3500 lbs which leaves around 3500-3600 lbs in the bed.
This means a upgrade in wheels or tires or rear suspension as they all need to meet or exceed the load you place in the bed from a TC.
Measurements are so close and you have the TC I would drop by a Ram dealer and take some actual measurements.
Someone may have the same combo so stay tuned.
