martyn8677's avatar
martyn8677
Lance 992 Actual Weight?
Wondering if any Lance 992 owners have actually taken their campers to a scale and got an actual weight? I am thinking of buying one, and based on this information from TruckCamperMagazine:
**Lance 992: dry weight, 3,290 pounds + 45 gallons fresh, 375.3 pounds + 6 gallon full hot water heater, 50 pounds + 2x 20-pound full propane tanks, 40 pounds + 2 batteries, 130 pounds + stuff, 500 pounds = 4,385.3 pounds
I believe my truck can handle up to approximately 4,500 lbs. If the above is accurate, I'm confident I can stay under that amount.
Anybody with actual weights?
Thanks,
Marty
  • I think you might want to take your truck and get it weighed. You can not rely on the info Ford publishes. I had a 2011 6.2 F350 with the max GVWR of 11200#. I have a 2012 10 2CDSE Northern Lite and I was over my GVWR by about 500#. This was with a camper loaded weighed a little under 3820#. I think you will be surprised that you are going to be over the GVWR.
    Take a look at Truck Camper Magazine Buyers Guide
    They show that camper when loaded will be 4385#.
    This is the weight slips from my 2011 F350 CC 4X4
    Total empty weight 7740#
    Front Axle 4400#
    Rear Axle 3340#
    With the camper on it
    Total weight 11560#
    Front Axle 4460#
    Rear Axle 7080#
    This is without anyone in the truck. So I was over weight by 360#. Not to bad but I was over my rear axle by 80#. This is with a camper that weighs 3820#. You are talking at least another 500# of weight so you are going to be will over your GVWR.
    You may want to get an actual weight on you truck before making a very big mistake IMO.
  • Ask over at the Lance forums, lots of friendly help there
