mkirsch
Apr 15, 2014Nomad II
I apologize for responding without knowing the exact answer to your exact question, but perhaps I can make some recommendations to help you find your answer.
Right off the bat, not many people use cabover struts. Nearly, possibly completely, NONE of the replies you will receive here will be based on actual experience. They will be almost pure conjecture.
Second, you are not going to find anyone in this forum who would be familiar enough with the structure of your camper at an engineering level to give you a educated answer.
Your first level of expertise would be the camper dealer. After that, you need to contact Lance directly for the answer. I suspect that they will give you the same answer as the dealer did: Not recommended. They will probably not expand on that answer or give a specific reason why.
Ultimately, nobody is really going to *KNOW* the answer to your question, not even the engineers who designed your camper. They designed the camper to handle the struts where the brackets are currently mounted. They did not perform any analysis on having the struts mounted anywhere else on the camper because they did not think anyone would want to mount them in a different location, so it was not worth the expense to perform the analysis.
You're basically on your own.
IMHO, is it really worth saving $600 to risk damaging a $40,000+ camper?
