fleecerdog's avatar
fleecerdog
lance camper plug
I am buying 2 seperate units ... a 2003 Chev 3500 dually and a 2000 Lance 1020. I've heard that Lance power plugs are different than others ... also, anyone know if the Chevy has a camper connection near the front of the bed? What did you Lance owners do? ... is this a case of 'adapt' or die?:h
  • Lance owner here. Just went through this. Yes, Lance plug is different and the only place your going to find the appropriate plug for your truck is a dealer or something like Ebay. Other dealers don't carry them. There is a small chance your new to you camper will come with one as they are supplied with every Lance camper. But, if not, contact a Lance dealer and either buy the plug for the truck and wire it in appropriately or get the 8' Lance extension which comes with the Lance plug on one end and bare wires on the other. You can then add a 7way plug to the bare wire end and run it to the 7way on your truck at the rear hitch location. This will get you using your camper and later decide if you want to permanently wire in the Lance plug in the bed of your truck.
    P.S. The reason the Lance plug is different is that 8 gauge wire is used to power the possible 12 volt fridge in the Lance. If your not going to use the 12 volt feature of the fridge then you don't need to worry about the 8 gauge wire requirement. The above instructions I gave you assume your not running the fridge on 12 volt.
  • RoyB's avatar
    RoyB
    Explorer III
    Be sure to check with ETRAILER. They have all kinds of adapters and extensions...
    Something like this may be just what you need...
    You can easily remote this connection to the wall of the truck bed...
    Roy Ken
  • Not a Lance owner but Yes the Lance plug is different, its advantage as I understand is it uses or will accept larger wiring for the power in. Which even IF truck had a bed receptacle you might want to change to utilize. Or add second Lance plug. There are quite a few threads regarding this- couple of older ones in the TCU as to wiring.
    But unless added by p/o truck wouldn't have bed plug and if it does likely a standard 7 pin & wiring (unless p/o had Lance). IF I had a Lance I would wire truck to utilize the larger power wire size potential (at minimum). Tapping trucks existing trailer tow wiring, its usually fairly small ga.
