Would some that has one please give me their wet weight, ready to go camping of the 2014 Lance 865 with optional generator? Lance lists it at 2700 pounds. Is that about right? Do you have a 250/250...
I think you might be confusing the 865 for the 855. I have the 865 which has a dry weight of 18xx lbs, mine weighs wet and loaded approx. 2600 lb. the 865 does not have a generator option. I believe truckcampermagazine.com did a match up of a 855 with a Chev 3500 and the 855 ended up wet and loaded approx 4000 lb, you could check that on their website.
