HaulinBass02's avatar
HaulinBass02
Leaking water heater question
I found that our Atwood E/DSI water heater is leaking. I'm fairly certain it's coming from somewhere on the bottom. It just started doing it in the past few days after having been filled and in use for the last few weeks. It only leaks when there is water pressure to it, if I cut the water off to the water heater itself it doesn't leak.....
Anything besides a small crack that might be the culprit? I can positively say it's not the fittings or the check valve. Has anyone been successful repairing it with alumaweld or something similar?
