towpro
Nov 21, 2020Explorer
what I ready they are saying is because the truck is so high so they put blocks UNDER the camper legs to allow enough room to lift the camper off the truck.
this spring while loading it one of the blocks shifted
What I would do is build a platform where the front and rear blocks are all connected. Remember you only need the front blocks to clear the tires, the rear blocks can be larger. You can still tie the front together with a treated 2X because the truck can drive over that with no issues.
If you build a small deck type platform with all 4 blocks connected, with a good foundation of some sort so they don't sink in I bet it would solve your problem.
