There are lots of good hitches out there but they are all different and some work certainly as good or better that others depending on lots of factors.
I use an Equalizer and have for many years. I chose this hitch because I did not want to deal with snapping chains into place and I wanted a hitch I could back up a trailer without disconnecting. Today, most hitches have worked out these concerns. I have also noticed that a lot of the newer hitches use the same basic physics employed in the Equalizer brand. The Sway Pro has replaced the rectangular torsion bars that rest on the L brackets with bars that connect with chains. This does reduce the noise factor.
There are ways to mitigate the noise in an Equalizer and I have used them and have very little noise in my set up. Again, there are lots of good hitches out there. I would look at many of them and ask how you hook up and unhook. You will find one you like better than the rest.
