BurbMan
Feb 16, 2015Explorer III
Nicholsfamily05 wrote:
The truck almost sits level still has a bit of a rake with it.
But yes unloaded it has a great angle leaving the rear end higher than the front
First of all, welcome to the forum!
Trucks are designed with that rake so that they sit level when loaded up. If you level the front end so it sits level when empty, the rear is gonna sag with the trailer on it. Unless you use the airbags to keep the truck level with the trailer on it, in which case it's gonna ride hard.
Leveling kits are helpful to fit bigger wheels/tires etc, but trucks that are built for off-road very seldom do a lot of hauling or towing.
Considering:
The truck 90% of the time is only used for towing
Then I would hold off on the leveling j\kit.
44,066 PostsLatest Activity: Jul 25, 2018
