DWeikert
Jul 10, 2015Explorer II
deltabravo wrote:Reddog1 wrote:
I had a pair of those, and gave them to my son in law. I really like them, but they were almost useless on hard ground or pavement. When I tried to drive up on them, they would slide away from the tire.
Another factor that makes them not so great is that the platform which the tire would sit on is far too small for my stock sized truck tires. Width is OK, but not the length.
If I understand correctly, your issue is the flat on each of the "steps" isn't large enough for the footprint of your tire as you drive up the ramp? Unless you're planning to stay parked on them for months at a time, I'm not sure that would be a problem. Do you worry about a tire sitting on a rock instead of all flat surface when you park anywhere else?
