- Reddog1Explorer II
DWeikert wrote:
I use a pair of these.
Camco Tri Leveler
Work for me...
I had a pair of those, and gave them to my son in law. I really like them, but they were almost useless on hard ground or pavement. When I tried to drive up on them, they would slide away from the tire. I concluded the first step was too steep. I may try another set, but only if I can bolt something on the bottom that would allow my tire to get on it, and hold the leveler in place. I think maybe a mud flap material the full length and about six inches past the first step.
I do cary legos. They are not as bad about slipping while driving up. More often than not, I just use my Stable Lift. - Kayteg1Explorer IIWhen I bought my camper, for couple of weekends I just unhook the camper and used the jacks to make it level. That was with front lifted off the bed.
That was not making it too comfortable and later I found some dryrot under front water tank that show some structural problems that I had to repair.
Lifting front without support under heavy tank is asking for troubles.
Now I carry lot of wood, just becouse I have tons of scrap wood laying around, but I think LEGO is the way to go on long run.
Still on my shopping list. - X2 on the Camco tri-levels. They are the best I've ever had.
I've used wood scraps, single-size plastic ramps, lego-thingies, digging a hole to lower a wheel, etc. - B-n-BExplorer III
Photomike wrote:
I picked up a set of the 12x12 Lego blocks and that does me for most of the sites that I camp at.
+1 Works every time. - PhotomikeExplorer IIII picked up a set of the 12x12 Lego blocks and that does me for most of the sites that I camp at.
- kohldadExplorer IIII carry two 4x4x10, two 6x8x10, four 2x6x18 (two per wheel), and a set of eight 12x12 plastic blocks. You may think it is extreme, but I can put a set of wheels up over 16" and have needed to do so in the past. Plus, with the ability to take such an unlevel site, I have more option and campgrounds to choose from. Some of the campgrounds I visit were built by the CCC and only designed for tent campers so no concern on making the parking area level.
Another use for the blocks and planks is I can use them to bridge up to a 34" wide washout over 20" deep. Haven't done it yet, but came very close to needing to in Kentucky. - narcodogExplorer III carry four 2x8x12's, they fit on the floor of the truck just perfect.
- DWeikertExplorer II
- WNYBobExplorerI do, they also keep the mud off. Plastic ones are lighter and have a case that contains the mud and dirt.
My drive where I store my TC has a slope, I use 3 under the front jacks and 1 under the back for a total of 8. That's what I carry. - dirtyhandzExplorerI have a set of those lynx level thingy's. I think it's just because I loved LEGOS so much as a kid. They have come in handy a few times. Generally I can find a pretty level spot to park it or find a few rocks or something to drive up on if needed.
