I have been trying to troubleshoot an exterior light problem on my son-in-law 2011 Dutchman trailer. The two exterior lights do not work. I checked the switch and it was okay. I changed the fuse for t...
Checked power to fuse and it shows 12v power. Next I checked light and 12v power is going to one side of switch but does not show any 12v power to the other side of switch when switched on. If I am checking this correctly, the switch is bad so fixture needs to be replaced. Would this bad fixture cause the problem with the red fuse light not coming on when fuse is removed? Thanks
