APT
Dec 16, 2015Explorer
The truck will do it, but as mentioned you are pulling two sheets (8'x8') through the air at 60+mph takes a lot of power, so any hills tap into reserve power. Naturally aspirated V6 engines do not have much reserve at 2500-ish RPM I expect you will be cruising at. As long as you understand and expect that ahead of time, you'll be fine. Let the speed float with the hills, speed up down, slow down up. Try to keep the torque converter locked as much as possible.
