rowekmr's avatar
rowekmr
Looking at 2000 Excursion 7.3L
I am considering a stock Excursion 7.3l for a daily driver occasional trailer puller and wanted to hear people's experience with the drive train. I have had 2 previous Excursions a V10 and a 6.0L modded.
From what I heard these engines are really durable but weak by today's standards. I have been told the stock trans is weak but some say they will hold up behind a slightly modded one.
I was planning on doing some upgrades with it later both the drive train and suspension.
From my prior Excursions I experienced weak suspension springs, expensive 4wd hubs that tend to go out and on one of them the wheel hub assembly needed to be replaced because of vacuum leak. Anything else I should know or consider?
  • Your first two were unsatisfactory so you considering third that is now 19 years old, correct?
    Specifically the first two had “weak suspension springs, expensive 4wd hubs that tend to go out and on one of them the wheel hub assembly needed to be replaced”
    lol
