Blanco1's avatar
Blanco1
Looking for idea on how to support my camper of truck?
I'm finally gonna take my camper off my truck due to the Kindness of site member AJCAL225
giving me some replacement used camper jack stands, yet don't wanna just leave the camper on just the stands.
So now I'm wondering how is it you guys support your Truck Camper when you take it off your truck?
It probably weighs about 3000 lbs as it sits & need some way to keep it safe?
I was wondering what & why you like whatever ways you do it?
I used CinderBlocks before but they are heavy & take up space when stored for future use.
I was hoping for a simple fast set up?
  • If you make your X pattern only 12 inches high, then you put two at each end instead of just one. This would then span the whole width of the base of the camper. Lay four two by sixes flat onto the X pattern, and set the camper down with the camper side edges supported by the two by sixes.
    This holds the camper off the ground at 13.5 inches up.
  • If I was storing on a flat surface, the plywood X would be my first choice. Nice advantage is with an extra piece of rubber, you could lay them in the bed of the truck to carry them with you.
    At home, I have a 5x8 3,500# capacity trailer I slide in under the camper then lay a couple boards across the rails and rest the camper down. Worked well and saved the camper from being totaled when a contractor backed into with the ladders on their trailer. Bent a couple of jacks, but the trailer caught the weight.
    Though I have been using the trailer for about 5 years, I've been wanting to make a nice set of saw horses. Not those cheap things from Lowe's as they don't carry enough weight. Only reason I haven't built them is I want to go beyond the normal and make the easily collapsible to fit in the bed of the truck before sliding in the camper so I can carry them with me.
  • Blanco1 wrote:
    I'm leaning towards this yet wonder what thickness would be right for the weight?
    Of Course I would also still use the camper legs.
    Naked, that 'X' design (made from 3/4", or 23/32" plywood, can hold a maximum of 2400#'s. But painted, they can easily support up to 2950#'s. This, as determined from the manufactures adjusted paint index for customized lumber products, available on line.
    You're going to hear a dozen stories about how that will never work, or plywood has no strength that direction, or it's a great idea and will support a loaded 11' camper with quad slides.
    Those and a set of 4x's across each one (so that edges of the frame are supported) and your jacks would probably be just fine. And cheap. And take about 30 min to cut up. Paint, well, that's to anal for me. But it's pretty for sure.
  • I'm leaning towards this yet wonder what thickness would be right for the weight?
