JJ says wrote:
Jim how about this,
how about you craft the question for me to use, using whatever information you want me to ask for replacing my ST 225x75R15 LRD tire… 5200 pound axles, 9500 pound trailer with a 10,000pound GVWR 1100 pound tongue weight…
however the question must also contain full disclosure on my intended use for a RV trailer in the US, and that it came originally equipped with ST tires…
or craft the question for me to ask, and to make it easy for you plug any numbers you want into the equation, but again the question must have full disclosure with nothing hidden…
Why would I want to load the question to gain another canned answer ??
You've already did that with Vanco so why do we need more of the same load the question to get a know answer ??
Or ask the simple question like this poster;
Hello,
I am needing to replace the tires on my travel trailer. My trailer weighs right at 6000 pounds ( on the CAT scale ) with 5350 pounds on the tandem axles. I am looking at Vanco 2 LT tires. I see that the Vanco tire in my size would be a 225/70R-15C, with a load capacity of 2470 pounds at 65 psi. This would give me 9880 pounds of load capacity, while I have an actual load on the axles of 5350. This leaves me with over 4400 pounds of extra capacity.
My wheels are load and pressure rated for 2820 pounds at 80 psi, so I have more than adequate capacity to inflate to 65 psi. They are 6" rim width, which falls into the appropriate width for this tire as I read the chart.
This seems like a good match for my use, as I would like to have the quality advantages of a light truck, commercial tire.
Is this a good choice ? Thank you,
Answer:Thank you for contacting Customer Relations at Continental Tire the Americas, LLC.
The Vanco 2 tires would be a great choice. The Vanco 2 tires have reinforcement that allows it to perform well on travel trailers. Thank you for your interest in our products and we appreciate your business."
It simply depends on ones agenda.
