AdvancedQs
Mar 21, 2022Explorer
trail-explorer wrote:
What your is your truck?AdvancedQs wrote:
Hang on. I might be wrong about the model of Arctic fox. I thought it was a 990.
Sounds like the 811 then. In the kitchen, are there three cabinet doors over the sink/stove, or two?
The 811 has only two cabinet doors up there.
Have you weight the truck empty and with the camper loaded?
My gut says you are still way over the GVWR of a 2500, but the same truck bed would be used on all of the same era of Dodge / RAM trucks, so that really doesn't mean the truck bed can't support the weight since 3500s and duallys run heavy campers and the bed doesn't crush.
It has two cabinets above the sink. Just like you are saying it is definitely an 811.
Now, I’m not too worried about the weight when it comes to the rest of the truck. I’ve already gone 150,000 miles with it. This isn’t the type of situation where a truck camper sits at a house and then once in a while it gets put into a truck to go to the campground. This is full time traveling all around all over the country. 150 thousand miles with the truck camper in the bed. It works just fine. What doesn’t work is that the bed is crushing.
