JRscooby
Mar 21, 2022Explorer II
AdvancedQs wrote:JRscooby wrote:
Do I see a dent in the right fender inside the bed. This makes me wonder if camper is moving side to side in bed. The crown in road would make it hit right side harder.
Yes. You do see a dent in that fender. The camper is definitely moving side to side. That fender is not where it should be because the bed is bending.
Well, maybe not side to side. It slowly moves over to the passenger side. Due to the crown of the road just like someone had just said.
I can go thousands of miles without it moving. But then with just the right combination of bumps and heavy crown on the road, it starts to slide over to the passenger side down the bent part of the bed.
Do you understand something no heavier than a bottle jack will dent the front of bed if it can slide back and forth less than a inch? Something as heavy as a camper sliding just a little bit is beating the bed like a pretty big hammer. No matter how you repair it, unless you solve the movement issue, it will not stay fixed.
